TN75 Cab A/C question
   / TN75 Cab A/C question #11
well does it still blow cold air even with the noise ? if so id have them do just the clutch on the comp. unless its still covered with warrantee. clutch is much cheaper then unit and thats more then likely the noise just my 2 cents
/forums/images/graemlins/frown.gif
   / TN75 Cab A/C question #12
</font><font color="blue" class="small">( well does it still blow cold air even with the noise ? if so id have them do just the clutch on the comp. unless its still covered with warrantee. clutch is much cheaper then unit and thats more then likely the noise just my 2 cents
/forums/images/graemlins/frown.gif )</font>
Just curious why you think it is the clutch and not the compressor. I expect it ot be the bearings in the compressor, not the clutch. The clutch is an on/off device and when it turns on, it trying to spin up the compressor that causes the noise. If it was the clutch wouldn't he noise be happening all the time?
Andy
   / TN75 Cab A/C question #13
This squeal lasted about 10 seconds and would recur about every 3-5 mins and quit. She had the A/C on and was just going at a steady pace
sounded intermintting to me Andy I'll Have to wait for more info low hours on Tractor I know thay go bad daily so it could be barrings. But drit and dust rase heck on A/C Clutches . " turn on and then off the A/C " test would help out but they do cycle by them self too hence 3-5 min thing makes me think clutch /forums/images/graemlins/smile.gif
Sorry it has taken me so long to get back on. My belts have not squeaked anymore. After a sit down with the boss, I found out that instead of shifting to a faster gear, she was a little over-reved. So we all learn a little. Thanks in response to all your help.
   / TN75 Cab A/C question #16
</font><font color="blue" class="small">( Sorry it has taken me so long to get back on. My belts have not squeaked anymore. After a sit down with the boss, I found out that instead of shifting to a faster gear, she was a little over-reved. So we all learn a little. Thanks in response to all your help. )</font>
So, AC is fine, just operator error? That is great news!
Bob
   / TN75 Cab A/C question #17
Bob
22 GALLON SHOP VAC (A58374)
22 GALLON SHOP VAC...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
New/Unused Forklift Jib (A57453)
New/Unused...
2017 John Deere HPX 4x4 Gator Utility Cart (A56857)
2017 John Deere...
DOOSAN G25KW GENERATOR (A58216)
DOOSAN G25KW...
(2) 5/16-3/8 RATCHET BINDERS (A52708)
(2) 5/16-3/8...
