RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,143
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
Yes for sure it is not but i have no idea where this f.. switch is !
The pto lever is on the right aft of the throttle !!
Your PTO NSS is under the tractor at the bottom right side of the transmission housing, in front of the right rear tire. There is a little hydraulic cylinder that activates the PTO clutch linkage; the switch operates off that linkage. If the cylinder doesn't quite return all the way, the switch doesn't trip leaving the circuit open and the lamp on. Adjust teh switch a little, that will probably cure it. The switch has a black body and white contact button. The electrical connector has 4 contacts, as there are two sets of contacts within the switch. One set normally open, one set normally closed. The same switch is also used on the park brake linkage on the left side.
