TN75S Power shuttle error code
   / TN75S Power shuttle error code #11
I have sent a note asking the customer for more documentation. The problem with him is that it is a pass-through. It came from someone in his network and he is trying to dig out the details. I'm sure it will come, it'll just take a while to get to the facts.
Since you have an obvious familiarity with these, have you ever seen failures that couldn't be fixed by rebooting of reflashing?
I've gleaned that they can be flashed. If so, I imagine that would correct a number of the problems and enable dealers to upgrade the ECU.
My primary interest is in electronics that have reoccurring failures. Sometimes the correction of a minor problem can greatly improve the satisfaction with an otherwise reliable machine.
Bo
I have seen more failures that could not be corrected by reflashing than those that could. Reflashing sometimes helps, or corrects a problem but only for a short while, or has no effect at all. More often than not, a problem with an ECU will be uncorrectable, and will require replacement. Whether they can be repaired on a cost-effective basis in unknown. I spoke with a technician at the premier Ag electronics repair company in the US (Ag Express)about a year ago, he had not attempted to fix one of these units at that time.
Ammco Brake Machine (A53424)
Ammco Brake...
CROSSTECH 4200X 57" HYD BRUSH CUTTER (A51406)
CROSSTECH 4200X...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2019 Ford F-150 Crew Cab 4X4 Pickup Truck (A53422)
2019 Ford F-150...
