TheMan419
Veteran Member
The only warning I will have is I cut the shaft for my tiller and THEN got the quick hitch...... oops. Shaft now too short. If you are planning a quick hitch/pat's system do that before you cut as it will change the length of shaft you need.
Other than that cut it how you want it and be done with it.
Measure 5 times, cut twice.... meaning first time you cut go a bit longer than you think you need..... test it out and cut a bit more off if you need to. Better that than being a bit too short.
