To tarp or not to tarp?
   / To tarp or not to tarp? #21
Edrobin and Roy. Both of your tractors emailed my tractor and asked me to convey to you the type of tarps that they WANT to cover them. Here is the picture they asked me to send you. I believe there about $94,000. so get to it.
   / To tarp or not to tarp? #22
Automobiles and tractors are designed and manufactured (mostly the paint) to be left out in the weather. Power company bucket trucks, heavy construction dozers and school buses live outside, except for visits to the shop for service. Sitting idle, covered or not, is what causes the greatest damage.
   / To tarp or not to tarp? #23
Hang the tarp from the roof to cover the open side and keep out wind driven rain/snow.
I agree with this idea, and I live in the rainy place. Cover loosely and never to the ground. Keep the straight moisture off and leave enough moving air to evaporate away what condenses on the 'sheenery. If the space is more enclosed in a vapor barrier, the ground under it should also have a vapor barrier on it, and the space and metal mass should be heated to a temperature above the ambient. Keeping a 'positive temperature gradient' in such a partially ventilated space will help it stay dry. Let the machine get cold, and remain colder than the air, it will draw moisture.
   / To tarp or not to tarp? #24
Nice tent...I'm sure my 4400 would appreciate it...I'm sure my wifey wouldn't!
   / To tarp or not to tarp? #26
well whu ya going to listen to...the wife or the tractor:p
Well.....at least the tractor don't talk back!!
Maybe the wifey is a bit grouchy...probably cold in that bucket and we're approaching the PA Turnpike...heading west!
   / To tarp or not to tarp? #28
Plastic or tarp on ground and breathable soft car cover on top, preferably one with built in elastic to keep it in place, green critter killer pellets on ground...done. I use the above system for my attachments as well as my trencher for our nasty NY winters.
   / To tarp or not to tarp? #30
I have a 24x48' tractor/equipment barn and can keep my Massey out of the weather completely enclosed. I used to have a problem with critters 'til we got a Jack Russell Terrier. She'll spend hours every day cleaning out the small critters which she brings home to show us her prize.
Last winter she got into it with a big ole' coon. We had to break that one up with a shovel. At 15 lbs. she wasn't much of a match for that 25 lb. coon. I will say she alerted us to it's prescence and had no intentions of of backing down.
   / To tarp or not to tarp? #31
The green critter killer pellets are OK so long as you don't use them near your house. Tried these a couple of times in a back shed and attached barn. The tiny critters found their way into the walls of my old house and died there. Wasn't very pleasant for a month or so. Tried plugging every hole I could find, but a farm house built in the late 1800's isn't so easy to seal up.
   / To tarp or not to tarp? #32
If you are worried about moisture build up if you put a tarp over the open side of the shed.....use shade cloth instead.
...If you get 90%UV rated cloth it stops rain and snow from getting in the shed.
It breaths so no moisture build up so you can cover the opening all the way down to the ground.
It does allow light in and helps deter visits from little invaders...... and as an added bonus in summer helps keep the shed cool
just a thought
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2005 INGERSOLL RAND WL-440 WHEEL LOADER (A60429)
2005 INGERSOLL...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
