LD1
Epic Contributor
It sounds like the way you flipped them to gain width kept the tread design
in the correct direction, if your tires are in fact directional.
You mentioned a while back that you had removed the tires from the rims yourself. Except for the 1" offset of the hub mount area are the rim beads
the same profile on each side of the rim?
The normal position for valve stems on Fords and on CNH New Holland is the inside to give them a little more environmental protection.
My tire guy usually cuts a piece of old tube to line the inside of the tires before putting in the tube. There is a flexible steel mesh liner for some tire sizes that gives even more protection to the tubes from puncture.
Yes they are ag tires so they are directional. And yes they maintain the correct direction.
The bead profile...I dont recall noticing any difference.
