crazyal
Super Member
The only reason I could see for using a WD hitch would be if you exceeded the limit of your receiver, either trailer weight or tongue weight. I thought you posted that it was rated for 5000 lb (without wd). If you know you are under that and have the load so it's not going to put too much weight on the receiver then I can't see any advantage to using a WD hitch. All the talk about how they work is just fodder that doesn't add anything to your question. As for why not use it even if you don't need it I would say why not double (or tripple up) on the number of chains/ straps holding down your load? Because you don't need them, why waste the time.
