To vent or not to vent that is the question?
   / To vent or not to vent that is the question?
Well you'uns convinced me, I will do a double vent and just cap off the low one in winter and maybe both when it gets really cold. Thanks,
Will make it 8x12 with a 8x4 outer room with 5' sidewalls and 7' at the peak.
Now am contemplating weither to use salvaged metal roofing that I have or buy treated 3/4 inch plywood 50$ a sheet before shipping ouch . I have a bunch of herculite that I got off the slope to cover it with before I back fill with sand/gravel and then the top layer of dirt/sod.
I have a bunch of 4x4 cedar that I beachcombed for studs/joists and was wondering if 18"centers was enough or bring them in to 12"? Have never built underground before so am open to all suggestions.
Thanks,
Rick
How bout it folks any input on if old steel roofing would work and how close to make the studs/rafters. I needed some dirt to mix into the compost heap and started digging a couple of days ago where I want to put the root cellar and ran into really firm clay about 3 feet into the hill. I cut a vertical trench into the clay and gonna see what rain and time do to it. It seems really stable so I might not have to worry about stuff sluffing off much at all when I dig it.
Rick
   / To vent or not to vent that is the question? #13
I don't know about your moisture, but you might try a big piece of PVC pipe for a stack. Set it low and close to the floor or use a 90 angle on the end. Cap it with a plastic cap when you don't want a vent. This would cause it to draw low, pull off moisture and or odors, without a lot of heat loss? Our storm/ root cellars used to always be moist and smell earthy..even with cement blocks and paint.
11 ft Shipping Container (A55973)
11 ft Shipping...
2022 Horizon Trailer (A55973)
2022 Horizon...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
