Today's cheap plumbing valves
   / Today's cheap plumbing valves #11
I have done many heat and plumbing jobs. I have always tried to buy the "Watts" brand valves and accs. Never had a problem with any of them. Be very carefull buying from the big box stores. Many products may look the same but they are not, for quality. They sell Cub Cadet and John Deere riding mowers at the big box stores around here. BUT are they the same ones with the same parts that you buy at the tractor dealers???
   / Today's cheap plumbing valves #12
I have battled this problem for years. The cause in my area is dezincafication. That is the zinc in the brass is leached out of the fitting by the water. The cheap valves are yellow brass. The old yellow brass had more zinc and lasted longer. The solution, is to install red brass also called bronze valves and fittings. That is the same material your water meters and city installed fittings are made of that last life times. Expect to pay $25 to $30 for a bronze 3/4" full port ball valve. That is the only solution other than going to plastic, which I do not consider an option. There may be a system that treats the water but it would be $1000s and require a lot of maintenance.
   / Today's cheap plumbing valves #13
I have a ball valve that doesn't work. My dad recently passed away and I am taking care of his house which is now empty, I went to shut off the main water valve and nothing happend. The handle on the valve rotated normally but when I opened a faucet, the water flowed like normal.
Anything I can do besides replace the valve?
   / Today's cheap plumbing valves #14
Bought a freeze-proof sill cock last summer to replace one that was probably fifty years old. Had I been able to take the old one apart I would have just replaced the seal in it, but it was pretty well frozen and I goobered it up pretty good trying to get it apart. I bought a Chinese replacement at Menards and will be replacing it again when the weather warms up. It started leaking about five months after I installed it. At least I get to practice my soldering skills.
Chuck
There is still water pressure in the plumbing system downstream of the valve after it is closed, so you will continue to get flow from a faucet until the pressure is gone. I have never known a ball valve to malfunction in the way you describe...check to see if the faucet finally sputters dry after a few seconds of your opening it --after closing the ball valve.
If the valve is defective, the only way to properly replace it is to first shut off the well (assuming you use a well) or have the public utility shut off the water valve underground outside.
Chuck
"Goobered it up"...never heard that term before...good one !! :laughing:
   / Today's cheap plumbing valves #17
I have had the stem break on ball valves. It is rare, but it happens. Most of the time it is a cheap valve that hasn't been used for several years. It is much more common with gate valves. The stem threads go bad and when you tighten it to turn it off, the threads break and it won't raise back up. You then are shut off and can't turn the water back on.
   / Today's cheap plumbing valves #18
I plumbed professionally for over 20 years. Get high quality valves. Your water quality sounds like it needs attention. If you clean up blue stains from your fixtures that means you have low ph. The blue is your copper plumbing system. If you have red stains on your fixtures you have an iron problem. that will corrode your valve and every time you go to use it grinding will distroy the valve. I have bought cheep mail order valves before that never shut off the water or leaked outside the valve right out of the box. The disadvantage you have from your plumber is your plumber will stop using poor quality valves that cause him problems. You are only working with a few valves and need to find out which brands/ models to stay away from. I do a lot work in different fields that I have no experience in. One trick I use when doing something I have no experience doing is to imitate the pro's. I use the same materials, patterns, methods, ect. Go to a plumbing supply and ask your counter person for a good quality valve. Check the water quality. Maintain your water treatment equipment. Take the time to plan your job by asking questions and researching your job on the interweb. Just yesterday I tried repairing my welder. I did not search the web for repair instructions. I ended up taking more things apart then I had to breaking a few other things in the process. If I took a hour researching the repair I would have spent 1/2 the time with the repair. BTW it's still not fixed. But i was able to dismantle a volvo 5 cylinder motor to replace the entire pvc system with out any hitches cause I did my homework before I started the job. Took only 9 hrs. Good luck Tom
   / Today's cheap plumbing valves #19
I'm hoping that all the Conbraco "Pipemaster" valves that I just installed in the new house hold up! In the event that the valve body fails in any way, I like the fact that they are o-ring flanged at each end so that the body can be easily replaced. But they are still made in China.
   / Today's cheap plumbing valves #20
OK now yall got me where i cant sleep tonight probably, thinking about all the faucet and all the lines and valves i have put in the two homes i have, all of whick came from lowes or HD. At least the farm property i turn the water off since it may be months between visits and i dont want to come in to a water logged house just for that very reason. But here at my house if a line fails or a cutoff fails and its 4 hours or more till i get home, thats a long time!!
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A51573)
New/Unused 7ft...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
