Good point, and thanks Dave.
It didn't occur to me the ECM folks during engine development would benchmark flow some engine intake manifolds & adjust the A/F ratio code to each cylinder!
Great concept.
Thanks,
No prob. In a past life, I used to write low level code, but not for engines - so that was only a guess, but a semi-educated one
While not cheap, the engineering time you'd put into flow mapping the head for each runner can easily be amortized over the high volumes of engines being produced - it's a heckuva lot cheaper than adding individual runner airflow sensors to production motors. If the front end design software for the head is good/mature enough - you may actually be able to predict the airflow characteristics of each runner pretty closely.
But.... it's alway good to pretend the lab is in Missouri, and actually measure the results !
All this work tends to keep oil (and air) cleaner....
Rgds, D.
