Toilet Project - Need Help
   / Toilet Project - Need Help #31
I had a old camper toilet andhooked it up don't use one.
I did and at first and the "waste" sticks because there isn't a puddle in there to brake the fall.
The temporary cure was put 2 X's of paper in toilet and cover the bottom of the bowl.
tom
I found a can of Pam kept near the portapotty/rv type toilets work wonders.
A quick spritz before #2 and they don't stick to the dry bowl;)
Remember the TV ads about "cooking with Pam"?
So far haven't seen a TV ad about pooping with Pam:D
   / Toilet Project - Need Help #32
groan!!! NOW i cant get that image out of my head since i am the cook in this family.:rolleyes:
   / Toilet Project - Need Help #34
Skyco has now taken us to a memorable new frontier.
   / Toilet Project - Need Help #35
butt biscuits???
hmmm..... will this work with 15 month old's diapers, too??? maybe we can reuse 'em!
amp
   / Toilet Project - Need Help #36
A quick spritz before #2 and they don't stick to the dry bowl;)...
I think you are going a little too far here.
If you go to any RV lot and just look inside the units you will find that the high end ones have little hoses next to the toilet to take care of this problem after the fact.
Being a true cheapskates, we bought a low-end RV without the little hose but just kept a spray bottle full of plain old water in the bathroom. A few spritzes with a stream of water gets it all down the drain, and no premeditation is required.
Did I mention this is very low cost?
You guys just don't want to let this thread die:D
I appreciate all the replys. This will be used mainly in the fall during MI hunting season. The winter deep freeze normally holds off until after season ends, and the toilet wouldn't be used after that. A little antifreeze in the tank and bowl should be sufficient to prevent freezing.
I may have to upgrade my plans. I'm in the planning phase of having a pond dug near this site and the toilet usage will probably go up substantially from just being used in the fall.
   / Toilet Project - Need Help #39
You always hear people talk about how far a septic should be from a well - You never here anyone talk about how far the horse pasture or cow pasture should be from a well - What the difference?
   / Toilet Project - Need Help #40
I don't run animals near my well either. Same reason.
John Deere 2600 Display (A59814)
John Deere 2600...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Deere 310L (A53317)
Deere 310L (A53317)
CATERPILLAR D3LGP CRAWLER DOZER (A60429)
CATERPILLAR D3LGP...
