Oil & Fuel Too much fuel? PT422,120hrs
   / Too much fuel? PT422,120hrs #11
rmcconnell said:
Yeah, I think that it has to do with the float and seat. I'm no engine expert but all the black smoke leads me to think that it is getting too much fuel. Most problems that people seem to have are fuel restriction which would cause a stall. I seem to have lots of fuel and fuel smell.
There doesn't appear to be a float height set in the diagram.
I'd also say that I have good fuel flow because when I open the carborator drain screw it pours out of there for a while.
I had this same problem many years ago also. Took me a while to figure it out, and like you, I pressed the float one day and it clicked on me that a float full of fuel has very little compression to lift the needle into the seat. I am also thinking that your fuel tank is above your engine, and that gravity will let the fuel slip by the fuel pump, and fill up the carb and then over flow, causing the symptoms you had. Did you change the oil that was in the engine. If you have not found a new float yet, you can maybe fix the leak by using a hot soldering iron and reseal the leak. You can test your repair by putting the float under water, squeezing it and look for bubbles. Somewhere in the engine manual there will be a picture of the carb upside down, showing the distance from the float edge to the rim of the carb. This distance is necessary to allow enough pressure to fully seat the needle when the bowl is full, and prevent flooding.
I replaced the float last week (Sept 7th). I also drained the oil, which was full of gas again. After starting it the engine sounded good. I didn't get a chance to mow until two days ago. I runs like new!
Thanks for the help everyone.
   / Too much fuel? PT422,120hrs #13
We are all glad you are back up and operating. It doesn't take long to diagnose problems and fixes on this forum with all the knowledge that our members have, and are willing to share.
Unused Delta Crash...
John Deere 9470R (A53342)
John Deere 9470R...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
