Took delivery.. WOOT!
   / Took delivery.. WOOT! #11
Regarding the 50 hour service. There are more than one thread here about bleeding the hydraulic system after replacing the fluid and filter. If you don't, you will fire your tractor up expecting to lift the bucket (and in my case box scraper) and get nothing but a tractor with it's engine running and paralyzed hydraulics. There really isn't a bleeder valve anywhere, but you can bleed at the hydraulic pump apparently, or where I did it at the filter. Made a bit of a mess though. Find the threads and read up first, it will be well worth the time.
Thanks for the hoe info...still outta range for me...
Have fun!
Oh.. ok thanks. I gottcha now on the 50 hour service. I will most likely do the service myself so I will read up on it.
I have some more pics... some from when I was first trying to remove the bucket... some others from last night when I was cutting in 40 degree weather. One picture is a knocked up cat if anyone is interested in orange kittens in NE ohio and finally a crushed beer can which gets me through each day. Others are of my back yard and all that I have cut so far.
   / Took delivery.. WOOT! #13
Afternoon Jacob,
Very nice looking machine !!! The best of luck with it ! One suggestion, try downsizing your pics a bit, it would be much easier for us guys that arent there to look at ! ;)
Thanks Again !
BTW I use www.photosize
I set the option for attachments to come in as links. So when I click on them the explorer window resizes them to fit the screen and the resolution is great.
If you set your options to links, I think you will have the same luck.
If I'm wrong let me know... I can take the pictures in VGA.
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
1999 Ford F-450 (A57148)
1999 Ford F-450...
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
2016 INTERNATIONAL WORKSTAR 7600 (A58214)
2016 INTERNATIONAL...
CEA 9' Rake (A57148)
