Tool to remove valve cores?
   / Tool to remove valve cores? #1
Mith
Veteran Member
Any ideas on how to make one. Just filled one tyre with water using a small screwdriver to remove the core but the other tyre valve core is stuck, need a tool to remove it. Any idea how to make one, all shops closed beace its sunday.
Thanks for any ideas
   / Tool to remove valve cores? #2
16d nail with a groove cut into it. Chop off the point, then cut into it from the end. May be able to do it w/ a hacksaw, or a Dremel for sure................chim
worked like a charm, thanks
   / Tool to remove valve cores? #4
A cotter pin can also double as a valve core removal tool.
sorry about bumping an old thread, just offereing up alternatives
   / Tool to remove valve cores? #5
</font><font color="blue" class="small">( Any ideas on how to make one. Just filled one tyre with water using a small screwdriver to remove the core but the other tyre valve core is stuck, need a tool to remove it. Any idea how to make one, all shops closed beace its sunday.
Thanks for any ideas )</font>
I keep at least one valve cap on my tractors that has an end
on them for removing valve cores.
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
Towable Diesel Tank (A53421)
Towable Diesel...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
