Tool to remove valve cores?
   / Tool to remove valve cores? #1
Mith
Any ideas on how to make one. Just filled one tyre with water using a small screwdriver to remove the core but the other tyre valve core is stuck, need a tool to remove it. Any idea how to make one, all shops closed beace its sunday.
Thanks for any ideas
   / Tool to remove valve cores? #2
16d nail with a groove cut into it. Chop off the point, then cut into it from the end. May be able to do it w/ a hacksaw, or a Dremel for sure................chim
worked like a charm, thanks
   / Tool to remove valve cores? #4
A cotter pin can also double as a valve core removal tool.
sorry about bumping an old thread, just offereing up alternatives
   / Tool to remove valve cores? #5
</font><font color="blue" class="small">( Any ideas on how to make one. Just filled one tyre with water using a small screwdriver to remove the core but the other tyre valve core is stuck, need a tool to remove it. Any idea how to make one, all shops closed beace its sunday.
Thanks for any ideas )</font>
I keep at least one valve cap on my tractors that has an end
on them for removing valve cores.
Galvanized Livestock Gates - (2x Gates) (A55218)
Galvanized...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
1271 (A50490)
1271 (A50490)
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Light Tower (A52377)
