Toolcat Snowblower trouble
   / Toolcat Snowblower trouble #1
Dakota handyman
Bobcat Toolcat
Good afternoon all, I have 2006 toolcat and a 2014 SB200 snowblower. I am able to get the main augaur to turn, but am unable to get the chute to move left or right, not adjust the pitch. Any quick recommendations? Thanks in advance!
   / Toolcat Snowblower trouble #2
What is the history on it?
Did it work before?
Did it work before?
I recently purchased both pieces, hooked it up yesterday, and while hooking it up, I thought I had moved the chute. Since what I thought moved the chute initially, I cant troubleshoot the issue.
I’ve checked the fuses, and connection, to no avail. My next step would be to test power to the snowblower and attachment connection.
   / Toolcat Snowblower trouble #4
Hello and happy new year,
To help you with this,
1. purchase a can of electrical contact cleaner to clean all connections that can be removed and then reinstalled
2. purchase a can of the clear aerosol gel foam from your local NAPA Store that will keep corrosion out of the
electrical connections as well as the 12 volt lightbulb and beacon sockets
you need to find any hidden in line 12-volt blade or cartridge fuses examine them with a high intensity LED light like a Larry Light
first to check for a broken/blown fuse as it is possible that a cartridge or blade fuse fuse can work and not work.
If your fuse blocks in the cabin are exposed to the elements you should think about putting them in a weatherproof enclosure or
see if bobcat has an electrical upgrade for this.
2014 420F BACKHOE (A47001)
2014 420F BACKHOE...
Komatsu D51PXi Crawler Tractor Dozer (A44571)
Komatsu D51PXi...
METAL SHELF (A47001)
Club Car Carry-All 1700 4x4  Utility Vehicle (A47809)
Club Car Carry-All...
Long 1537 Rototiller (A47809)
Long 1537...
P&H OMEGA 20-20 (A47001)
P&H OMEGA 20-20...
