Tooth bar, tooth spacing
   / Tooth bar, tooth spacing #1
CraigM
Golden, IL
B2150HSD, JD3020
I'm going to build a toothbar for my B2150 (24 HP). I found a place reasonably close that stocks teeth and shanks for skid loaders, but before I go shopping, I'd like to have a better idea what I'm looking for. Can anyone out there with a machine similar to mine tell me the approximate size of their teeth,and the spacing between them. What I'm looking for as far as the size is how wide are they and how far do they project past the factory cutting edge on the bucket.
   / Tooth bar, tooth spacing #2
I've a 54" bucket. My toothbar has 8 teeth.
Obviously, one on each end and the remainder equally spaced between. That comes to 6¾" spacing approximately, measured to the center of each tooth.
Each tooth is about 1¼" wide. The groove the fits onto the bucket is allows the toothbar to overlap the bucket about 6". The ends (where you attach to the sides of the bucket) is about 7 or 8 inches.
You'll need to determine how many teeth you want. Eight seems to work pretty good. Then, depending on the width of your bucket, you can calculate the spacing.
Remember the old carpenter's adage "measure twice, cut once". Of course, I didn't pay attention to that...so I've two holes on one side the bucket.
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
Zero Turn Mower (A48082)
Zero Turn Mower...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
