Toothbar in winter?
   / Toothbar in winter? #11
I always take mine off before the first big snow. On year I had to put it back on after a lot of ice, then took it right back off. Clearing snow is much easier without it.
   / Toothbar in winter? #12
The only time I put mine on in the winter is sometimes I'll use it when I'm bringing firewood into the garage. With it on, I'll get a few more sticks on the loader so I don't have to make so many trips. Other than that it stays put on the rack.
   / Toothbar in winter? #13
I only put mine on when doing dirt digging work. It's off most of the time. Works better with mulch, as a wheelbarrow and with snow without the tooth bar.
Ralph
   / Toothbar in winter? #14
Ralph
DITTO THAT : i only put mine on when i need it, never in the winter!!!
   / Toothbar in winter? #15
I just removed my toothbar since I don't suspect I'll need to dig in dirt or anything like that in winter. If the ice gets too bad, I reckon I'll put the toothbar on just long enough to help break it up. I don't think that should be too necessary though.
   / Toothbar in winter? #16
hey b8,
I have thought about doing a hockey rink in the snow...do you just pull snow under the loader and flatten it out? Then spray water and eventually fill with water?
Thanks.
   / Toothbar in winter? #17
D--no I don't go that far (only used by 6 and 7 year olds) I just flatten out a large enough area, push some snow banks for goals and let 'em have fun--sometimes I even join in! No skates and think they would rather be sledding if they are outside anyways.
   / Toothbar in winter? #18
Depends what your projects involve. Personally, I keep the toothbar on in winter...the ground is frozen and I go to work on the burn piles and pushing around stumps and fallen tree debris that can't be done during the wet season. Winter is heavy work season for me, so I keep it on. I also like to backdrag over my crushed rock driveway to loosen it up a bit for some traction on the incline. Since I usually backblade the snow with a rear grader blade, I don't have the need to use my loader for this function...so the toothbar stays on in winter. That's me though...there's plenty of others with a wealth of tractor experience that will do the oposite. The nice thing about toothbars is they are very handy and come on/off easily with minimal time and effort...especially if yours is set-up to swing back into the bucket for storage. Enjoy!
   / Toothbar in winter? #19
Have not taken mine off yet but plan to do it.
However, it came in use today. We had 15 round bales delivered and I worked on getting them arranged with the 3PT spear. When the farmer dumped them off several were on their side. I used the the loader and bucket curl to push them right side up. The tooth bar was very useful. It was very slippery and the toothbar dug into the bale to ensure it wouldn't get away from me.
   / Toothbar in winter? #20
I just went home last night after work and used mine.
We had freezing rain on top of snow the other day and the ground had a thick blanket of ice on it. It made walking a little treacherous. So I un-curled my FEL and smashed up the ice enough to make the surface all broken up so it is easier and safer to walk on now.
2005 Military Trailer (A53424)
2005 Military...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
JLG 460 SJ TELESCOPIC MAN LIFT (A52707)
JLG 460 SJ...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2009 Pontiac G6 Sedan (A55853)
2009 Pontiac G6...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
