Toothbar installation with cordless drill
   / Toothbar installation with cordless drill #1
GarageSmoker
Dade City, Fl
Kubota L3010 HST
Talked to Carver this morning and they didn't think it would be possible. This is a problem because there is no power on the land. I suppose I could drive it to the closest house and plug a drill in, but what do you think? Can an 18 volt 1/2" drill cut the mustard drilling the holes? (Assuming enough batteries on hand or time between charges)
GS
   / Toothbar installation with cordless drill #2
GarageSmoker,
I've been doing some drilling in steel lately with my cordless and although it is a time consuming activity - it can be done. Better get an extra charger.
   / Toothbar installation with cordless drill #3
Have at least 3 or 4 batteries charged and ready.
   / Toothbar installation with cordless drill #4
What about renting a portable generator?
   / Toothbar installation with cordless drill #5
I wouldn't try it but I GUESS it could be done. Biggest problem with drilling a hole that big with a small drill is if the bit bites it'll wrench the drill out of your hand pretty easily. I used a hole hawg cause it gives you enough leverage so that won't happen. If using a small hand drill you have to be pretty careful or you can twist your wrist pretty badly.
   / Toothbar installation with cordless drill #6
I drilled the holes in my HD bucket for my toothbar using a Craftsman 16.8V cordless drill and a bimetal hole saw. I was about half way through the second hole when I had to change the first battery out. I don't think you'll have any problems.
--Brad
   / Toothbar installation with cordless drill #7
I drill 1/4" angle iron with my Dewalt 18 volt all the time. I don't think that it would be any problem to drill a bucket lip with it.
   / Toothbar installation with cordless drill #8
Why rent a generator - now you have justification to buy one./w3tcompact/icons/grin.gif
Good point on justifying the generator. I can probably get the power company to put my construction power pole in also. I just thought of that. I might as well give the cordless a try though. Sounds like others are being successful.
GS
   / Toothbar installation with cordless drill #10
It will cut the mustard. Just take some time thats all. But the good thing is on low you won't burn your bit up either. I think you will be surprised at how well it will do. Just be careful not to overheat the drill. Also keep some oil on the bit and you will be using your toothbar in no time.
Gordon
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
