toothbar theories
   / toothbar theories #1
digger2
n.e. pa.(lycoming co.)
kubota B26 TLB,former B7610 owner
I'm thinking about a toothbar or adding teeth to the cutting edge of my fel bucket.Alot of guys are saying "man,the difference is fantastic" or "these
toothbars,how did i ever do without one".
Are they really that great,do they really make that much difference?
And if they do,is it in moving dirt or when do they make that much of a difference?
Any theories on why they make such a difference?Do the teeth break up the ground more easily than the cutting edge does or what?I've never actually seen one in use.
I gotta know before i pull out my wallet and order.
digger2
   / toothbar theories #2
Digger2:
Toothbars are more efficient at penetrating denser materials than a straightedge FEL cutting bar. I believe it is a function of force applied to a smaller area (ie teeth) at the point of contact. I did not believe the difference until I attached a toothbar over my cutting edge. If you want to move dense material I would recommend a toothbar. Jay
   / toothbar theories #3
They are especially good at moving around tree debris on the ground. Back dragging to pull out roots and scrape debris into a small pile. Good to scrape dirt from an uprooted stump. The teeth will also loosen hard soil as a 1st stage in leveling an area. With a bar vs fixed teeth you can remove it or loosen and flip it into the bucket so you can use the smooth cutting edge for finishing.
larry
   / toothbar theories #4
digger2
Yes, they are a most benefical addition. If you are as tight as what I am reading here, you'll find your best deal at Markham Welding - Home. Quite a few folks here have their product. They do a good job, quality product and a very decent price. Best I have found in all aforementioned aspects.
   / toothbar theories #5
I have a bolt-on Markham toothbar and at $350 delivered I'd say it has been a good value. I am not as enthusiastic about toothbars as some on TBN but that is probably because I don't do much digging with the FEL and the toothbar didn't add all that much in other uses. Don't expect it to turn your bucket into a backhoe for digging efficiency and don't think it will replace a grapple arm on your bucket to manage brush or logs. However, I'd still agree that it is a worthy addition to any bucket that is not being used to just scrape poop or move sand/sawdust.
   / toothbar theories #6
Two other advantages/uses I've found - they act as 'mini pallet forks' for carrying wider, awkward loads like large, flat rocks. And, fully-curled and driving backwards, they're great for pulling/moving long sections of fence fabric!
-Brian
   / toothbar theories #7
-Brian
I agree an example:
   / toothbar theories #8
jbrumberg said:
I agree an example:
What's that blue thing connected to your toothbar?
k
   / toothbar theories #9
kbota:
That blue thing showed up in my driveway one day. Apparently it needed a place to stay. I use it to walk my rocks :D. Jay
   / toothbar theories #10
That's funny. Nice looking rig. Excellent job explaining toothbar physics.
k
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
