Top and tilt hookups complete, thanks mountainview ranch!
   / Top and tilt hookups complete, thanks mountainview ranch! #1
Illini22
Northern Illinois
2013 Kioti dk40 hst, wright stander zero turn
I ordered a top and tilt setup from Brian (mountainview), who I believe is the owner of fitritehydraulics. It was delivered last week, just as he said it would. I opened the packages and installed it yesterday.
First the packaging. The cylinders and hoses were encased in rigid foam insulation, very nice way to prevent damage. The 90* fittings and nipples were in plastic bags with plastic collars protecting the threads. 2 of the hoses had tags on them directing me to install in the cylinder end. 2 of the quick connects looked like they had an additional nipple between the hose end that I'm not sure why. But, I'm sure Brian will know. Everything went together as it should with no leaks!! Now I just need a box blade to justify it, lol.
I had a very positive Experiance when I bought my Kioti from the turf team in Morris il. I then purchased a grapple and forks from Titan ind., and had another positive Experiance. It has continued on from Brian at fitritehydraulics. Their are a few people on this great site that seem to be never happy with dealers. Venders. Etc.
I must be lucky because these 3 company's have have been great.
   / Top and tilt hookups complete, thanks mountainview ranch! #2
Those extra fittings are your flow restrictors. ;)
Remember when you get that box blade, as heavy as you can afford. 800+ lbs would be a good place to start.
Good luck and I'm glade that your experience has been a positive one. :thumbsup:
   / Top and tilt hookups complete, thanks mountainview ranch! #3
It is good hear of a positive experience. You will love the TNT. I was going to recommend a QH to go with the TNT but I see you have one. They work great together.
Brian, thanks for the info about the flow restrictors. I keep looking for a box blade on CL and eBay. Havnt found anything yet. And I'm really holding out for a rollover, based on your info (usually heavier too?
Roger, yes I do have a cheap harbor freight qh I bought 6-7 years ago for my kubota b7100. So far it's holding up, but with a heavier tractor and larger implements its life may be limited, lol. Tim
   / Top and tilt hookups complete, thanks mountainview ranch! #5
Congratulations on your Top and Tilt, you are going to love it, I use mine with a Land Pride HR3584 box blade and agree having used a lighter one a heavier one works much better.
   / Top and tilt hookups complete, thanks mountainview ranch! #6
Tim either a 60" or 65" will fit your tractor about PERFECT. I run a 66" Gannon with my Mahindra 3215 HST and it is a perfect match IMO.
Will you stop rubbing it in with pics!�� lol
   / Top and tilt hookups complete, thanks mountainview ranch! #9
Nice product , do you make up the hoses yourself ? I like the flow restrictors .
   / Top and tilt hookups complete, thanks mountainview ranch! #10
No not at this time. :( I have a place that makes them up for me at a reasonable cost. ;)
2004 JOHNSTON STREET SWEEPER (A58017)
2004 JOHNSTON...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
Freighliner Tender Truck (A56435)
Freighliner Tender...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2019 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58017)
2019 FREIGHTLINER...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
