Top and Tilt with Pat's Hitch
   / Top and Tilt with Pat's Hitch #1
Bendboater
Bend, Oregon
Kubota L2501
This is probably a dumb question.....but I don't know the answer so hopefully someone can help me out.
I am seriously considering adding Top and Tilt to my Kubota L2501. I used to have a Quick Hitch (triangular frame), but I gave it away because it was so difficult to hook implements up (too hard to get the geometry right). Instead, I went with the "Pat's" system which has worked very well for me. So my question is, if I do add Top and Tilt hydraulics, can I continue using Pat's system or will I (should I) need to go back to a Quick Hitch?
   / Top and Tilt with Pat's Hitch #2
I have a hydraulic top link with Pat's and regularly use it's full length of travel with no issue on a blade, brush hog etc. I can't see a tilt being an issue as you'd have plenty of twist in the lift arm bearings to not stress the Pat's hitch, which in itself is not too wide to cause binding. I think you'll be fine.
   / Top and Tilt with Pat's Hitch #3
If you have Pat's and have been happy with the Pat's, stay with that type of QH.
Just be sure to get a longer top link to allow for the added length of the Pats.
I provide a 23"-35" working length for your model when the customer has the Pat's QH.
I think that you would find that the std full 3pt quick hitch works quite well when connecting implements when you have a top & tilt set.
If you want to step up from the Pat's, maybe consider Euro type draft link ends.
Lot's of options, just something to consider. :)
Good information. Thanks guys.
   / Top and Tilt with Pat's Hitch #5
I have the Pat's QH on my 2502 with hydraulic top link and love it. I think the Pat's is a great QH system.
   / Top and Tilt with Pat's Hitch #7
Been using Pats and T&T on my Kubota for 3 seasons, 2 mowers etc., no problem. Kept my original Top cylinder and added a 4" spacer on the tractor end.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1999 NUTTALL FOUR AXLE TRAILER (A58214)
1999 NUTTALL FOUR...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2018 Ford Transit 150 Cargo Van (A56858)
2018 Ford Transit...
