Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
My Kubota L4300 has three holes; top, middle and bottom; where the 3-pt hitch toplink can be attached. I have position control only. The manual has little information on how to choose the proper hole, but there is a table that gives some guidance on tillage attachments. The middle and bottom holes seem to be favored for most everything. The top hole is only recommended for a mouldboard plow operating in 'light soil'.
When using my Woods HBL84-2 rear blade, I've found the toplink is closest to being level when the blade is in operating position when it is attached at the TOP hole. In the middle and bottom holes it's angled up toward the implement sharply (maybe that's the goal).
Anyway, using the top hole gives me more (useful) travel on my hydraulic toplink. In the middle hole, the toplink is nearly fully extended when I have the blade set the way I want. Adding Pat's EZ hitch to the lower lift arms complicated matters by moving everything further back.
What basic principles apply when choosing which hole on the tractor the toplink gets attached to? Does weight of the implement affect this decision? What about the height of the toplink attach point on the implement? Does the top hole have less mechanical advantage than the lower holes or put more stress on the tractor? Of the three, the top hole has the least attaching structure supporting it. Even the manual waffled a bit and said the table guidelines might not apply to all implements.
Bob
Bob
