Top link breakage
   / Top link breakage #12
Does anyone know what the parts would be for a B2400?
   / Top link breakage #13
Tractorman or Kubmech, are these parts the same for a 4310GST. The cost of the ones listed are about 150.00 total. Not too bad an investment to make me feel better about the tractor.
Many thanks for the info!!!!
Greg H
   / Top link breakage #14
All the grand L's should take the same parts................
   / Top link breakage
<font color=red>Funny with all the people that are liable to view this forum before purchasing a tractor, I haven't seen one post from a dealer or manufacturer's rep to dispute the need to purchase the H/D link mount. The picture of the J/D 4300 torn up is just a nightmare /w3tcompact/icons/mad.gif, is this something that all top manufacturers have overlooked /w3tcompact/icons/blush.gif?
   / Top link breakage #16
Kubmech, The quick response is appreciated! For the life of me I cannot , looking at my tractor, visualize how the mount could go on. care to give a pointer or 2?
Greg H
   / Top link breakage #17
Ho Boy. Right now I'm thinking a picture says a thousand words. Let's see if I can do it in less than that......
You should have an L bracket with some holes in it, a smaller bracket with 4 holes in it (that's the left one) another bracket with 3 holes in it (that's the right one).
Looking at the back of your tractor where the fenders and seat deck mount to the rear housing you should see two brackets. Remove the brackets. Two bolts hold each bracket to the housing and one (15/16 or is it 7/8 I forget, should work) hold the seat deck
(should be a rubber washer/bushing isolating it). Find something to lift the back of the seat deck up (I use an overhead hoist, but I cheat) This should give you enough clearance to work.
On the left side of the rockshaft housing remove the two 17mm head bolts just forward of the 3 point top arms and install the 4 hole bracket through the existing holes. You'll need to use longer bolts due to the bracket thickness. Don't tighten them yet. On the right side remove the nut just fwd of the 3 point top arm and slip the right bracket over the stud and install the nut. Now remove the existing top link brackets.
Pay attention to the angle in the bottom of the brackets, that's how they go back on later.
Now take the large L shaped bracket (with the smaller holes on top and slide it over the top of the rockshaft housing, the 6 larger holes should line up with the holes of the top link brackets. Start the bolts in the upper brackets previously installed (may need spacers/washers between them). Re-install the top link brackets to the original position with longer bolts. Once all the bolts are started you can tighten everthing down and reassemble the seat deck.
Hope that made sense.......................
   / Top link breakage
<font color=blue>A bit of an update. I e-mailed Kubota the same day I posted this topic. I described the problelm and mentioned the talk on at least two popular web sites. No reply as of yet /w3tcompact/icons/mad.gif
   / Top link breakage #19
Is the heavy duty top link needed when only using a three point hitch, or is it recommended using a box scraper etc.?
   / Top link breakage #20
The HD top link is included as part of the kit for a backhoe. So I think the implication is that a backhoe can overdo the top link. That said, if the LD bracket breaks loose, it's very expensive to fix. I think a boxblade prbably doesn't put the same kind of load on the toplink as a backhoe, but who's willining to bet?
(2) HANSON 100# DRAW SCALES (A58374)
(2) HANSON 100#...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2012 WESTERN STAR  4900 SB INOPERABLE (A58214)
2012 WESTERN STAR...
Utility Tilt Trailer (A55787)
Utility Tilt...
