Rich B1
Veteran Member
- Joined
- Jan 28, 2017
- Messages
- 1,162
- Location
- Stone Creek, OH
- Tractor
- NH TC21D, 3 Craftsman GT’s…..old but tough, AGT Industrial QH 12
Restrictors are your friend in simple hydraulic systems. The components are designed/made for general purpose hydraulics with a wide range of application/use.
The top link application becomes a bit more precise/high end than the intent of the basic system. As in, it is expected to be a precise cylinder for positioning/holding that is beyond the basic system design/manufacture. At least in my opinion.......
When correctly installed, the restrictors should allow free flow into the cylinder, restricted flow out of the cylinder. Ideally you figure out what size orifice works aver a broad range of applications and have an orifice check on each port that gives you speed and more importantly control over cylinder movement.
But none of really have time to get an ideal solution, so the Parker type adjustable flow restrictors get the job done with a bit of fiddling. Due to the difference in area, you will likely end up with different settings on each end of the cylinder.
One thing nice about the adjustable type is if you get a new attachment, you can tailor your settings if needed. Or not.
Keeping lines and fittings small also can help to add some restriction to help with limiting speed and adding control.
