Top link pin Question
/ Top link pin Question #1
N1ST
Enfield, CT
Kubota B7800
The top link pin for my KK tiller fit perfectly through the tiller hole and top link, but the pin is too small for the larger top link hole on my cultivator. I tried using a washer but it made the pin too short to reach through (and it would be sloppy inside the bigger diameter holes). Do I need a bushing for the cultivator, a longer top link pin, the same diameter top link pin but with a bigger head???
Ahh, thanks.
Willl said:
You can get category 2 to 1 bushing adapters.
...but this wont fit through my cat 1 top link, will it?
/ Top link pin Question #5
you can use two short bushings (they come in various lengths) on either side of toplink hole ...although I would get a new pin that was longer and had a bigger "head" (or handle) and only use the two bushings if for some reason I didn't like the slop.
/ Top link pin Question #6
The easiest solution is to buy a Cat2 toplink and use a bushing to attach it to your tractor and then use a Cat2 toplink pin for your Cat2 implements...
