Top N Tilt Cost
   / Top N Tilt Cost #11
True.........if you already have two remotes and levers, then you only need the cylinders and hoses.
   / Top N Tilt Cost #12
Hi Mad
I am in the process of adding the top n tilt to my B7500. I have the 2 remotes on the back and need to order the cylinders. But what sizes are required? And, I am just guessing here, but do I have to order a standard tilt rod from Kubota and cut the ends off and weld them to the new cylinder? Also I have read about flow restrictors and pilot relief valves. Are these needed or do they just make life a little easier?
Al
   / Top N Tilt Cost #13
Call Mark Carter at CCM (www.ccmachinery.com) and get one of his top links with the pilot operated check valves. Price will be $170 + shipping. He also sells hose kits but you can do better at www.hydraulichosefittings.com. I recommend 1/4 inch hoses.
The tilt link is another story. If you really want/need one then you have 2 options as I see it. Either get the TCC tilt link from Integration Engineering or make one yourself that will more approximate the geometry on your B7500.
There are several good recent posts on TNT. Here and Here .
I would get the top link first and then decide if you need the tilt.
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
