Top .. Tilt Cylinders for my JD
   / Top .. Tilt Cylinders for my JD #1
sureshot
I have a small John Deere tractor ( 3320 ... 33.4 HP ) and I need top/tilt hydraulic cylinders .... Can anyone help me locate .... Thank You ! ... John
   / Top .. Tilt Cylinders for my JD #2
   / Top .. Tilt Cylinders for my JD #3
Welcome to the site.
"I have a small John Deere tractor ( 3320 ... 33.4 HP )"
Not as small as you might think around here and the 3320 is 32.5hp and it's PTO is 25hp.
Many folks on tbn like the CCM cylinders. There is a dealer in IL on ebay that sells them as well I believe. Maybe Marion IL area?
Do you have the JD 3rd SVC or the Diverter valve setup at all on your 3320?
Enjoy TBN.
Thank You ! very much .... I'll call and see what I can do .... Thanks again ..... John
Thanks for your shout .... Actually all I do is mow the lawn with the3320 and it does a good job ... I have a 55hp and a 65hp JD's for the rest .... I have a little box blade ( 60" ) that I want to grade dirt with a top and tilt .... Oh you might be right on the HP ... My manual says 33.4 and I called the dealer and he said 33.4 .... The John Deere site says 32hp ... Whichever it mows very well .... Thanks again .... John
   / Top .. Tilt Cylinders for my JD #6
I have the 4600 and now need the tilt, still have to climb down to adjust tilt, top link is CCM hydraulic, it unlike the deere has the pilot valve that locks it in a little better. If I could figure out how to get that valve plumbed in neatly on that surplus center cylinder I would get it. But I am giving CCM a few months before I Rube goldburg it.
   / Top .. Tilt Cylinders for my JD #7
I recieved it today and thought you might like some photos. Looks Very heavy duty. Hole for pin is 1" and original one is 7/8". Alaskanjdeere
   / Top .. Tilt Cylinders for my JD #8
Another...
Toro Mower (A50324)
Toro Mower (A50324)
BRADCO 42" MINI HYD TILLER (A52706)
BRADCO 42" MINI...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
