Toro vs Gravely Diesel ZTR
   / Toro vs Gravely Diesel ZTR #11
Justin,I've got the 28hp Kubota in my Grasshopper and have had no problems.IMO if you are going to spend big $ on a ZTR you should check out the front mount decks. russ
I second the recommendation to look at front mounts. I bought a Bad Boy ZTR this year. My neighbor (whose whole property is in grass) bought a JD front mount.
I really like my BadBoy but the front mount has 2 significant advantages.
1. You can mow close to fences and obstacles in front of the mower. I cannot get close in corners.
2. You can tilt the front mount deck up. This allows easy access for maintenance and a smaller footprint when parked.
   / Toro vs Gravely Diesel ZTR #12
The reason I was considering the Gravely and Toro is that they are the two I found to be most comfortable other than Deere, which doesn't have too good of a reputation as of late.
Justin, Take a look at the Deere 997 Diesel - the Z800A Series mowers were the ones that had a few issues - that has never been a problem with the 997 as it is a completely different unit. Available with 60" and 72" decks.
   / Toro vs Gravely Diesel ZTR #13
To All Members:
I have 4 Gravely 2 wheel walk behind machines and 10 attachments for sale. I am in NW Connecticut. Contact me for more info. Thanks!
Stuart
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2020 Ford F150 (A53422)
2020 Ford F150...
