Torque Multiplier
/ Torque Multiplier #1
Robert Bolton
Columbus, Texas
John Deere 790
Does anyone have a reasonable source for a torque multiplier with a 750 ft. lb. rating?
Thanks, Robert
/ Torque Multiplier #2
/ Torque Multiplier #3
I just use a bigger impact wrench myself. If my 1/2" drive IR won't do it, my 3/4 will and if that won't do it, my 1" will.
/ Torque Multiplier #4
Heck I simply use a length of pipe that I slip over my ratchet or on my tire X bar.
Twice the tool length= 2x the torque.
LOL, worst wheel had me propping the X bar on a cement block, length of pipe and me jumping on the extended X bar. Loud 'crack' and I landed on my azz.
/ Torque Multiplier #5
I bought a used US made one similar to this from eBay vendor.
/ Torque Multiplier #6
I have a 5' length of 1-1/2" pipe that fits comfortably on a 15" crescent wrench and a 50-lb. spring (fish) scale that gets me to 250 #'. 750 #' would be 125# at 6'. Torque value tolerance is + or - 10% so you do not have to be precise at 750 #' (that's tight, 1" grade 8 bolt, 1-1/4" grade 5).
/ Torque Multiplier #7
...and when the head fails and it becomes a missle and whacks you in the noggin, you'll wish you didn't use a cheater pipe.
/ Torque Multiplier #9
Lots of them out there.... I picked up one a few years ago at a a flea market for an astronomical price of $10..... It's a 4:1 multiplier, it will take up to 250ft-lbs on input applying up to 1000ft-lbs on output.... Mine is very similar to one below.... 1/2 drive on input side 3/4 inch drive on out put side....
Google search will show all different types and pricing from about $50 to $2000 depending in your needs....
IF its for only a one time use, check with local tool rental place or auto parts that loans tools, no point in buying one if its not going to be used a lot...
/ Torque Multiplier #10
Anybody who uses a extension pipe on a RATCHET is just dangerous ........ I have broken 3/4 breaker bars and they are more stout than most ratchets... Firm believer in torque multipliers after breaking two 3/4 breakers bars and then having to take project to truck tire shop and have them use 1 inch impact to get flywheel gland nut loose...This was pre torque multiplier days...
/ Torque Multiplier #11
I have the Neiko larger unit listed in the first link. It's not rated for impact use and the ratio on it is slightly off per one of the reviews and they are correct. I've used a few times to torque/break loose rod caps in cylinder rebuilds on my backhoe.
/ Torque Multiplier #12
I don't believe any of them are impact rated. All rated for manual force far as I know. Be too easy to apply too much twist with an impact tool.
/ Torque Multiplier #13
My highest torque requirement - inner nuts on the tractor rear wheels - 225 foot pounds. That's a snap with my 3/4" breaker bar. My big torque wrench goes to 250# - so, tightening is no problem either.
/ Torque Multiplier #14
Impact is not the solution for all stuck items. Sometimes you need slow steady MASSIVE force to break things loose or move them. I recall one good example where I was using a ball joint press (basically a giant C-clamp) to press out a ball joint on a front suspension arm of my wife's exploder several years back. I used the impact wrench (hi powered IR 1/2" one) and it would not budge. But even an 18" breaker bar with steady but serious force applied would move it. I have run into this multiple times over the years. I always start with impact as it is the Easy Button but there are cases where I know it isn't likely to work and am ready to move to a breaker bar and even possibly a pipe extension on it to get something to move. Just the voice of experience...
/ Torque Multiplier #15
Fun fact is the OP just asked for a torque multiplier, without giving any details of why he need it in the first place, which is not needed anyway. As far as I know, an impact may not even work for the OP's situation or he simply wants to torque something a bit more carefully than just slam an impact on everything.
/ Torque Multiplier #17
Darn! Another tool I need.
Ha ha! For a long time I know I've needed one (I've got stuff to un-stick things; I don't have things to tighten to spec anything over about 110 lbs-ft), and then I run across this thread and I feel ashamed... Need to figure out how I can order one of these things off of Amazon without my wife knowing (I use her account)!
BTW - The NEIKO PRO 3/4" is rated to 2,200 lbs-ft. That's hazardous duty category!
/ Torque Multiplier #18
Interesting experiences for you. I have seen the opposite. I have broken lug bolts off when using a breaker bar. Frustrated, on the same wheel, I took the time to get my impact wrench. Got the rest off without breaking another and didn't grunt or sweat either.
/ Torque Multiplier #19
I got some black iron pipe in plumbing section, 3ft sections 1" to 2" with adapters so I can use what's needed for the job.
/ Torque Multiplier #20
Should be able to buy a multiplier on eBay at a decent price, haven't used my Proto for quite some time, not since cordless impact wrenches came out, some 1/2 inch cordless goes to 1200 ft.lbs.
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
JMR TREE BOOM (A61572)
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2022 EZ-GO ELITE...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
