Torque Values for Gear Pump Reassembly
   / Torque Values for Gear Pump Reassembly #1
mmranch
Crested Butte, CO
TYM T603
I have a gear pump (with aluminum body and cast alluminum end flanges). I need to reassemble and was wondering what torque value to use for the 4 assembly bolts?
Thanks for any ideas!
   / Torque Values for Gear Pump Reassembly #2
PTO? Hydraulic? Primary or secondary pump? Need some more info.
ETA there are generic torque value charts as well you can use when all else fails.
Thanks for the info!
The pump is the main hydraulic pump (18cc-r)... (I guess it's the primary). It is driven off the engine gears (there is also a second power steering pump driven off the same gears but it is not disassembled currently).
The 4 assembly bolts have allen key heads. I haven't yet measured the bolts and threads but I will.
Thanks again.
Thanks for this info! I've torqued the assembly bolts down.
Thanks again.
New Kivel Skidloader Double High Back Bale Spear (A50775)
New Kivel...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
Roll off Dumpster (A47477)
Roll off Dumpster...
UNUSED Mini Excavator Rake Attachment (A47477)
UNUSED Mini...
2016 Dodge Ram 5500 Lube Truck (A55788)
2016 Dodge Ram...
