Torque wrench size for use on teactor
   / Torque wrench size for use on teactor #1
Mike from MI
Bellevue,Mi
Kubota l3200 hst 2014
What size torque wrench should I buy for use on tractor 3/8 or 1/2". What are good brand's to go with. Have never owned one and have no idea what should I be looking for.
   / Torque wrench size for use on teactor #2
For checking frame, loader, wheel bolt / nuts etc you need at least a 1/2" drive torque wrench plus a long extension (for doing the deep wheels). If you want to do smaller bolts / nuts in inch pounds (instead of foot pounds) get the 3/8" drive. Sears Craftsman, Mac, Snap On, S-K, are all good. I use S-K and Craftsman torque wrenches in my garage.
   / Torque wrench size for use on teactor #3
I have a Craftsman 1/2 inch and a Mac.
   / Torque wrench size for use on teactor #4
You are going to need at least a 1/2. I have a Ford f-350 that requires 140ft./lbs. for the lugs on it. Farm equipment like disk mowers require 3/4 or 1 inch. Doing engine work is where your numbers really mean something.
   / Torque wrench size for use on teactor #5
Determine the biggest torque setting you will use and buy accordingly. As others said loader mounts or wheels, possibly ROPS.
   / Torque wrench size for use on teactor #6
1/2" Craftsman for me also.
Thank everyone. Looks like 1/2" will suite my needs as of know.
Mike
   / Torque wrench size for use on teactor #8
Hmmm. Trying to make the same decision. My biggest worry has been 450ftlbs required for my bush hog, wheels and other items.
3/8 or 1/2 may do it, but much more is required than just your basic wrench?
   / Torque wrench size for use on teactor #9
450 ft lbs? How can that be done? Two people stand on the handle? A 10' cheater bar? Wow.
HF has the 1/2" (well, all of them actually) for 9.99 pretty regularly. Seems pretty nice, says 4% accuracy.
   / Torque wrench size for use on teactor #10
Bushog blade bolts I just tighten to stall with a strong 1/2 impact on a short air line. Those bolts will take 1000ft# easy. Overtightening is seldom possible.
larry
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55302)
2025 Wacker Neuson...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
Kuhn VT144 (A53314)
Kuhn VT144 (A53314)
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A55788)
2014 Chevrolet...
Deere 450H (A53314)
Deere 450H (A53314)
Westing-Ouse 653J044G01 3Phase Generator (A53316)
Westing-Ouse...
