SeymourBota
Platinum Member
The simple solution would be to disconnect all but the feed and return lines to the tractor, push the controller up and then down and note which hoses move as they come under pressure. Then hook your quick hitch lines accordingly. That was how I got mine to work before the letter came from Kubota.
Raising and lowering should be the same as the FEL, as you need the float mode for snowblowing.
