Tourquing rear tires...
   / Tourquing rear tires...
195 lbs...so 27 inches if I stand on it. Lol I like the 40 inch breaker bar idea, won't get killed if it slips. My 3\4 drive set has the breaker piece and a ratchet, I just need a pipe.
   / Tourquing rear tires... #12
Basically, the way the torque, force & weight formulas work. You have a socket on a breaker bar that is one foot long. You apply 100 pounds of weight on the end of the breaker bar - there will be 100 foot pounds of force applied to the nut. The breaker bar is two feet long - apply 100 lbs force - there is 200 foot pounds at the nut.
The longer the breaker bar or cheater pipe is - the less force is necessary to achieve the same results at the nut or the longer the pipe and the same weight at the end of the pipe will achieve greater results at the nut. This is only approximate and if torque is critical then a torque wrench is the only way to go. For tightening lug nuts on a tractor I use a torque wrench - simply because I have one.
Watch out for this - long cheater pipe on a cheap breaker. You can easily break the u-joint and skin something up pretty badly. I have experience on this.
   / Tourquing rear tires... #13
3/4" breaker bar minimum. Bout all of em will handle the 445.
I wouldnt use a 1/2" drive. 445 is a bit much for one of them.
   / Tourquing rear tires... #15
   / Tourquing rear tires... #16
Yup that about says it.
Your not doing aircraft maintenance, your putting on 1 of probably 2 tires.
So do it, relax and have a pipe.
Hahaha...I do get carried away about doing it "right". Wife won't be happy if I tell her I need a 300 dollar wrench.
   / Tourquing rear tires... #18
Wife said buy a wrench and do it right. I love her.
CASE INTERNATIONAL 3950 - 21' DISC HARROW (A52708)
CASE INTERNATIONAL...
Portable Restroom (A54865)
Portable Restroom...
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A56857)
2025 GIYI GY-PG72C...
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
17307 (A55853)
17307 (A55853)
Cushman Electric Cart (A55853)
Cushman Electric...
