Tow behind batwing mower
   / Tow behind batwing mower
Hi there Thomas,
the seat takes most the stuff, not much flies up high enough to hit me. Hoping to have a cab done by spring when I'll be using it next. Thanks.
LB, if it is almost straight up then 14" should be plenty to mow out across them. The tractor with the duals is good up till 45 degrees across slopes, after that I worry about the engines ability to keep oiled.
Do you have a picture of these banks? Youve pretty much rejected almost every possible way of mowing banks for some reason or another. I dont think I would put any machine of mine near the top of a near vertical 12' bank. Too much chance of landslide. You should build a wall to support it.
   / Tow behind batwing mower #12
Neat idea but I don't think you would find me using it. It might be great for cutting grass but it would also be great at killing people with those exposed blades. Do yourself and everyone within about a 150 yard radius a huge favor and add some housing's to the blades. We don't want you or your neighbor to be the next candidate for the Darwin award.
   / Tow behind batwing mower #13
Mith said:
Hi there Thomas,
1*LB, if it is almost straight up then 14" should be plenty to mow out across them
2*You've pretty much rejected almost every possible way of mowing banks for some reason or another.
4*I don't think I would put any machine of mine near the top of a near vertical 12' bank. Too much chance of A landslide.
5*You should build a wall to support it.
1*I need up to about 3 or 4 feet to reach out over a road ditch.
2*Excep a telescoping mower.
4* That's the reason for the telescoping feature-to keep the tractor further away from the edges of the banks and ditches.
5* Wall not really practical as the long range plan is to fill the area in.
   / Tow behind batwing mower #14
I agree .
I would also make one of the wings teloscoping rather than folding or hinged.
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2017 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2017 GENIE GS-1930...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A53843)
2021 QUALITY...
