I' having trouble finding a tow behind spot sprayer that meets my needs. I've checked home depot, tractor supply, Fleet Farm, all the box stores...etc and searched online and am just not finding it. I'm hoping someone can point me to a brand I should look at.
I need a tow-behind spot sprayer in the 40 - 100 gallon range that I can pull with an ATV. The tank has to be round with no legs molded in the bottom or other unusual shapes where stuff can sit and make it really hard to clean. I want only a sump in the bottom of the tank. It must have a drain. I also want one that has the option of recirculating so that you can get some agitation to keep things in suspension. I want an electric pump and not a gas engine.
Seems like it should be relatively easy to find but apparently the guys engineering these things don't use them because certain things you spray have the consistency of paint and you mix in water and then the stuff clings to everything. I want something I with no nooks and crannies just a nice smooth round tank on the inside and then a single sump area in the bottom where the pick-up hose is located.
I know I could build one but don't have the time.
Any help would be appreciated. I did a lot of searching with no luck before asking here.
Thanks!
Thanks!
