Sprayer Tow Behind Sprayer
   / Tow Behind Sprayer #11
back several years ago the larger tank pump had almost twice the output of the smaller one. guess they changed it.
   / Tow Behind Sprayer #12
Mike,
I've used a 25 gallon tow behind sprayer from Northern for our riding ring. Think of the extra 10 gallons as 62% more capacity. Means you only have to go back and fill the tank twice instead of three times. $50 bucks doesn't sound so bad then. Depending on the size of your ring and what you are spraying, one 25 gallon load may not be enough, 16 gallon most likely isn't enough.
Jeff
   / Tow Behind Sprayer #13
Gary,
Can you list the components you used? I'm thinking of making a 3pt version using a 25 gal tank.
   / Tow Behind Sprayer #14
Don124,
You mentioned that the larger tank version, also has a larger pump. Can you tell me how far your smaller version will spray a stream? I need to reach the tops of 12 foot tall trees as well as reach horizontally about 15 feet.
Will your unit do that?
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A53424)
2001 Club Car DS 6...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
