Towing in overdrive
   / Towing in overdrive #91
Funny you say that as that is exactly the trip I took in June that began me to wonder if I had problems. It was that long, I think 7 mile grade, inside VA on I-81 and a number of other serious mountains.
Gave me a real strong re-appreciation of "Beach camping."
   / Towing in overdrive #92
Truckers take I-81 to avoid the one on I-77 NB. :D Both roads join and split near Wytheville/Ft Chiswell, VA. Which by the way, is a good place to stop for fuel. It's our last fuel stop NB and our second stop SB coming or going from here. And yeah, if you did that grade you probably saw a couple truck parked on the side of the road as there normally are one or two semis that have to call for a tow before they get to the top. Some that do make it are down to 5 MPH reaching the crest. Most loads are at 30 or less. It's a place where you don't want a brake failure either. But there are 7 escape ramps spaced a mile apart on the downgrade side. Snow storms on that strech are fun too. Even as late as May.
   / Towing in overdrive #93
Which is something I've done many, many times. The first Flying J I ever heard of was at Wytheville, although I've also stopped at several of the other "truck stops" for fuel or for a meal
Incidentally, the first "Outlet Mall" I ever saw was at Wytheville.
   / Towing in overdrive #94
And the weird part is, there are 2 Flying Js there.
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
