Towner FL93 Offset Disc Help?
/ Towner FL93 Offset Disc Help? #1
RedNeckGeek
Super Member
Butte County & Orcutt, California
Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
I just dragged home a Towner FL93 offset disc, or at least most of one. It came in two parts, and the previous owner wasn't sure how he had it together last time he used it. Having never used one of these before myself, I'm stumped on how the two pieces hook together.
Here are some photos:
Side view showing Frame A and Frame B
Name Plate
Top view
Top view of Frame A from the front
Top view of Frame A from rear showing adjustment mechanism
Top view of Frame B from the front
I've tried to label the major parts, pins, and holes in hopes someone can come up with a "insert Rod A in Hole B" type of assembly instruction.
I also need to repair or replace two of the discs which have large sections broken out of them. And there are a few missing trash scrapers as well. Before I go to all that trouble, is this thing complete enough to be worth salvaging? So far I've only got fifty bux in it, so I don't mind spending that much or a bit more to get it going.
Any help would be appreciated!
Thanks in advance...
/ Towner FL93 Offset Disc Help? #2
Name Plate
Top view
Thanks in advance,
Scot
I have an old 6.5 ft Towner offset that I use in my hayfield.
http://www.tractorbynet.com/forums/attachments/108965-offset-disc-up-close-personal.html
Mine is probably some version of the K-series. I don't have any specific info on the FL series.
/ Towner FL93 Offset Disc Help? #3
I've never seen a Towner before, and I'm definitely no expert, but shouldn't the rear discs be facing the opposite direction from the front? The way it is now, it would always pull the dirt to one side. Seems a bit odd.
Look at most modern discs. The front and rear sets usually oppose each other.
Joe
Air Hose Reel (A65640)
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
10ft. Barge Box Wagon with Hoist (A65640)
10ft. Barge Box...
2000 Sterling Rollback L9500 Series Truck, VIN # 2FZNEWEB1YAG12895 (A65563)
2000 Sterling...
Reddick Crop Sprayer (A62613)
Reddick Crop...
