Trac Vac PTO RPM problem. Advice requested/
   / Trac Vac PTO RPM problem. Advice requested/
Thanks Road. Once I settled down and started doing some math, this seems like less of an issue.
The 854 uses 4 pulleys whereas the 856 uses 2 - no big deal. If I keep the largest pulley coming off the gear box, I just need to buy 3 more and 2 belts. If I feed in 960 rpm from the pto, it should come out of the gear box at 1920 rpm. If I double it again, I get 3840 (the stated rpm of the impeller is 3800). If my starting pulley off the box is 6 inches (its close to that and I will measure it exactly) then I need a 3" to double my rpms. Then I just need to run identical 3" pulleys in place of the remaining 2 to keep 1:1 the rest of the way.
Should be fairly cheap and easy. I just need to figure out belts as the model 854 is not set up for adjustment between bore centers.
*Both photos borrowed from other members without permission - sorry. The 856 has been modified but illustrates the difference in the configuration of the pulleys.
Simply doing the math and finding something close from surplus center would likely work. If they have the same shaft size swapping might even be an option.
Surplus Center
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
