track comes off 1960 AC hd6 dozer
   / track comes off 1960 AC hd6 dozer #11
In the photos in post #8, that grease looks fresh, new.
Do you suppose the previous owner had it apart just before he sold it?
   / track comes off 1960 AC hd6 dozer #13
I had an old cat D69U that the cline adjustment got worn and it would walk out of it's track.. big ole grease cyl.. was a bear to fix..
soundguy
   / track comes off 1960 AC hd6 dozer #14
Nice shop you are working in.
   / track comes off 1960 AC hd6 dozer #16
It could be -20C in the shop!:p
Them things just never break down in nice places like a shop anyway!
   / track comes off 1960 AC hd6 dozer #17
man, working in that muck!:rolleyes:
all the tools are back at the garage.....all the lifting equipment......sheesh!:(
we're pullin' for ya!
   / track comes off 1960 AC hd6 dozer #18
Makes ya sick don't it!
soundguy
thanks for the support guys , got my bearings today and then found out my axle is broken at the outer bearing, and it broke there for the last owner as well .so Im looking for an axle and trying to figure out why the axles are breaking.
must be loose at the spot where the diagonal arm from the track frame attaches, although the caps are tight it must be where the problem is I think. was to dirty to get the camera out but I will take pictures tomorrow.
   / track comes off 1960 AC hd6 dozer #20
If the diagonal brace bearing is Ok , i think you should compare the measurements of the standard track frame on the other side and the one that has been fitted . Make sure the length of the diagonal braces are the same , the pad where the spring sits too the axle bearing cap centers etc , also the condition of the bracing on the blades 'C' frame as if that is crook the forces put on the blade whilst pushing can skew the track frame and put great strain on the axle .
2006 FORD F-250 (A52472)
2006 FORD F-250...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
