Track'd CATs
   / Track'd CATs #11
Ours were used in dryland broadacre applications, often under consistently high ambient temperatures (usually c.100F) predominately in seasonal 24/7 operations -direct drilling operations (for grain crops) & secondary cultivation
We found the turbo's didn't last long as the bearings fried/collapsed regularly & the best we could get out of the engines in the Cat 55/65/85 were c.6000-7000hrs before major rebuilds - we also had the 55 break a crankshaft at c.4800hrs & burn a piston prior at c.3200hrs, so maybe we had a dud.....
Comparatively the MT's ran without issues (except high track wear & a couple of collapsed track gear bearings), to c.6000-8000hrs before we exited from belted tractors, we're not hard on equipment as is evident from our older gear with high hours :
- an old Steiger 400hp with a CAT3306 still purring away at 29000hrs
- 2x White 4-150 with Cat 3208's fine @ c.12000+hrs ( a lot of people don't like the 3208's but we've always had a good run from them including in trucks & pump sets)
- 3x Acremasters 330hp mercedes V10's all fine @ 20000-36000hrs
IMO the CH55 should be ok for pulling your lettuce bed former (as they performed well in cotton on well tilled ground ) & discing, but if it's hard ground I'd be a little cautious on any heavy tine work ( like chisel ploughing ).....the rubber tracks usually wear ok in black/alluvial type soil (make certain to keep the rollers/idlers clear of soil at each day end) but experience exponential wear in granite or sandy loams....
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
