TrackSteer w/ backhoe trailer
   / TrackSteer w/ backhoe trailer #11
Appreciate the feed back. Currently looking at 14-16K trailers now. Was intending on just a bumper pull, but don't feel quite comfortable with a possible 16K load on a bumper pull. Didn't want to have to remove my work boxes and rack in my pickup to accommodate a Goose neck hitch. But may have to now. Anyone out there with a 16K bumper pull? I've got an F-350 short bed so I'm rated just not sure if I'll be pulling the trailer or it will be pulling me. Also, any good ideas on a work box w/rack set up for a goose neck hitch? Thanks again.
I can see where bed space would be at a premium with a short bed. I usually have a flat bed on my work trucks, there is an amazing amount of floor space lost with a pickup bed.
I had an F-250 (with a flat bed) that had 2 under body boxes, and top boxes down each side. Lots of storage space for tools you want to keep locked up. It had a rack that fit into the back standards (stake pockets) when needed, and had 2 rails that tied it into the headache rack behind the cab. When pulling a gooseneck the rack went to the front of the bed and was pinned to the headache rack that was permanently mounted, the 2 rails slid under the bed and pinned in place. It was a pretty neat setup, but I pull trailers often, so it wasn't utilized like it should have been.
   / TrackSteer w/ backhoe trailer #12
I have a Kaufman 15K equipment trailer and it has 7,000lbs axles. The added capacity over the 14K model comes from additional tongue weight. The trailer is built plenty stout to handle a few thousand pounds of tongue weight. When loaded heavy I use a pintle hitch and tow it with one of our 2-ton dump trucks, lighter loads I use the 2 5/16" ball coupler and tow it with my 3/4 ton pickup. Load capacity is 11,700lbs, but that takes a big truck capable of handling a lot of tongue weight.
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
Flatbed Trailer (A51694)
Flatbed Trailer...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
