Tractor cooling system comment (not a problem, just an observation)
   / Tractor cooling system comment (not a problem, just an observation) #1
beppington
Elite Member
of my
Here
I'm no tractor mechanic, & I've wondered a few times about how a tractor can keep itself cool enough when it's flippin' 100 degrees outside.
Well now I know - The other day I got off the tractor & put my hand right in front of the front screen, & the air flow over my hand was very powerful & very cool!! Almost A/C like! I was shocked!
I was sweatin' my butt off in the burning hot sun, totally soaked in sweat, & here the tractor is sucking in this seemingly nice, cool air.
I assume it felt "cool" to me due to evaporation?
What temp range does a normal tractor engine operate at?
   / Tractor cooling system comment (not a problem, just an observation) #2
I would have to assume that it operates about the same range as a car as they both run the same range pressure cap on the rad and the same range thermostat. Not to mention the same antifreeze.
The radiators are built more like truck rads though....
   / Tractor cooling system comment (not a problem, just an observation) #3
Engine temp is controlled by the T-stat look in your manual check the spec. of the T-stat and you will know. The gauge 1/2 point reading should be the high reading. Paul
   / Tractor cooling system comment (not a problem, just an observation) #4
I don't know the exact answer, but I'd think it would be in low 200 degree range.
   / Tractor cooling system comment (not a problem, just an observation) #5
My tractor runs at aprox. 190 degrees . and I agree putting your hand in front of the tractor would give the same affect as if were on the other side acting like a cooling fan what you feel is the fan drawing in the air and moving it over your wet skin. Paul
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
296385 (A57192)
296385 (A57192)
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
