Tractor FEL Crane *Update*
   / Tractor FEL Crane *Update*
I'm not a real big fan of those turnbuckles. If one fails, the whole geometry changes in seconds.
Your point is well taken. I do intend a couple of mods before "work begins":
<1> The cable clamps will be correctly oriented, as someone else pointed out that I have some of them on backwards - thanks for that observation.
<2> The turnbuckles are, as you point out, a point of concern. Once I tighten the turnbuckles to set tension, I will cinch a cable bypass loop around the turnbuckles so that in the event of a turnbuckle failure the cable will carry the stress safely until I can ground the system.
   / Tractor FEL Crane *Update* #12
Excellent slide Phil.You will find that works well for the trusses.. and other things as well.
Philcase
Attemp to limit bucket rotation with a load, it will move very, very fast with the tip that far from the pivot point. With that said....be careful looks like a handy tool to me..:thumbsup:
Thanks. I agree, bucket tilt is a rather course control at the end of the boom, which was another reason I added the winch, finer control. This allows using the tractor for course positioning of the trusses, then climbing onto the headers and using the remote winch control, and my hands, for final placement.
Wow, I like the ingenuity but the fact the tooth bar is really just riding on two small little sides of the pipe would make me nervous....no matter how tight you have the rigging. I know it's slid over a tooth but that tooth isn't holding anything.
I maybe would have built some sort of mount out of the next size up i.d. pipe and some flat stock that would have been welded to the toothbar and then slide your boom pole down into that pipe and then continue as you did, if that makes sense.
Be careful. :thumbsup:
I looked at this quite seriously, surprisingly there is very little horizontal (skew) torque against the tooth on the bar. There is approx 1/16 of an inch of horizontal play between the inside diameter of the pipe and the diagonal cross section of the tooth itself, the horizontal torque is so little that I can, by hand, "rattle" the boom over the tooth to the limits of this play.
My initial concern, was that the compression torque at the point between the bar (not the tooth) and the pipe is pretty extreme. My fear was the possibility that under load the pipe (3/16 steel x 2 edges) might fail under stress and split the pipe itself.
After testing with loads like myself and the generator, I see no indications of any stress. (indentures or cracks). I no longer feel this is much of a concern, but will look for signs of problems after each truss placement.
The steel cables, cinched up, would never stretch to the point that the pipe could come off the tooth -- They would fail long before that point.
As with all tools, the key is operating smart. Run it like you expect a failure and you will be safe.
   / Tractor FEL Crane *Update* #15
Quite an interesting bit of rigging, that is for sure, the only thing I would add for safety is securing that pole to your bucket somehow. Just using the counter force of the weight alone would make me more than just a little nervous. Perhaps a bolt that secures it to the tooth so it doesn't slip off.
Other than that, slow and steady, no quick movements and it should be ok.
   / Tractor FEL Crane *Update* #16
Nice job thinking outside the box and coming up with a solution to a problem.
Now, at the risk of sounding negative, for what you have invested in this contraption, you could have bought breakfast, lunch and a steak dinner and a case of beer for a good friend and have been a lot farther ahead IMO.:confused2: The type of work that I am seeing is done by a few guys in a couple hours all the time. And, others are right, it has the potential for a few things to fail. Regardless, I hope it works well for you and the main thing here is to get that barn built :thumbsup: Goodluck, use common sense and be safe. :)
   / Tractor FEL Crane *Update* #17
I guess I was a little surprised that the RC remote actually WORKS with the winch "hidden" in the steel bucket.
If your operating procedures are all worked out you will probably be OK, I would;
a) Only actually "carry" trusses with the boom all the way down, assuming the tractor doesn't tip forward on it's front axle if you do that.
b) Not move the tractor at all with a rafter on. Even if it is only a couple of feet off the ground it would only take a few degrees for the pull to get outside your front wheel track and it doesn't seem you can drop it quickly.
c) Absolutely make the guys on the top plates do the final positioning, no two or three inch tractor movements.
Good luck..... and stay safe.
Ummm, I think if you were a neighbor and I dropped by to help I would probably bring a helmet - full coverage (-:
   / Tractor FEL Crane *Update* #18
Looks like it should work fine for a set of trusses. I would caution against curling the bucket too far back as the pole could come down backwards on top of the operator.
I hope the truss job goes well and be safe out there.
   / Tractor FEL Crane *Update* #19
you should have 2 pipes and a good chain down the center dont ever trust those darn turnbuckles. they are rated way less than your cable. if one goes the load will swing sideways way more dangerous that way. look up winch trucks in the oilfield that will show you how to make it stronger and safer.also legs down from your bucket will stop a lot of stress on your front axle.
   / Tractor FEL Crane *Update* #20
Watch those turnbuckles. At the angle of that cable relative to the pipe, the tension in those turnbuckles is many times the weight supported by the boom. :confused2:
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
2017 Ditch Witch FX50 T22S Towable Vacuum Excavator (A55973)
2017 Ditch Witch...
HARD TOP FOR CONVERTABLE CAR (A58374)
HARD TOP FOR...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
flooring (A55758)
flooring (A55758)
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
