tractor for maximum traction
   / tractor for maximum traction #41
one could make a strain gauge out of a hydraulic cylinder, and a fluid filled pressure gauge, fill the cylinder full of oil and attach the gauge, if one needs a remote location one could use a length of hose, to the gauge, a valve in line could be used before the gauge to help protect the gauge, and I think there is some isolators that can help protect the gauge from shock loads, http://www.crosshydraulics.com.au/files/products/gauges&Accessories/FT291.pdf
or a GAUGE SNUBBER which is a part that has a micro sized hole so the gauge is not a direct of the complete force of the oil
https://www.google.com/search?num=1...msedr...0...1c.2.64.serp..0.1.463.HeZx3EmBEfA
attach the cylinder in between a pulled object and the tractor, by knowing the area of the piston and the rod of the of the cylinder, one can calculate the square inches and by looking at the gauge and the pressure created one can calculate the load that is being generated.
one could use a tillage tool for the load so it could be adjusted and tested on various soil types.
   / tractor for maximum traction #42
Maybe OMRAN will come back and let us know how he ends up addressing his question, given all this input.
   / tractor for maximum traction #43
Being pulled on is what they are made for. makes no difference up and down or side ways. And not many CUTs weigh over 22,000 and your not going to pull more then your weight unless your wheels a steel cogs running in a steel rack. I'm sure if you want to test the big AG tractors weighing 100,000 plus somebody makes a gauge to do that job for quite a bit more money.
I'd sure like to see a 22,000 pound CUT! :D
Here's a 100,000 pound AG tractor...
   / tractor for maximum traction #44
I have made a few strain gauges out of old hydraulic cylinders. Works well. And I have an assortment of gauges too in varying pressure ranges for more accurate numbers. The particular cylinder I use, IIRC, 1 psi is equal to 1.47 #. SO with a 3000psi gauge, I can measure up to ~4500#. But using a 3000psi gauge with 100# increments isnt very accurate for weighing something 400 or 500 pounds. SO I also have a 100psi gauge with 5psi graduations and a 300psi gauge with 10psi graduations.
As to pulling power, studying several nebraska tests, it seems the drawbar pull for a FWA tractors is usually about 10-15% less than their weight. For 2wd tractors, 20-25% less than their weight, and for 4wd tractors with equal tire sizes (like that big bud), drawbar pull is pretty much the same as weight.
But as mentioned earlier, there are alot of other variables. The nebraska tests are in ideal conditions and pulling from a drawbar. Pulling from an elevated hitch, or something that adds downforce as it is pulled (like a middlebuster) increases the weight over the rear tires and can increase pulling power. Likewise, if you are chained to a tree 10' high, as you pull it takes weight off the tractor and can decrease power.
   / tractor for maximum traction #45
Well, seeing Big Bud, I wonder.....
Are the rear tires loaded...what about the front?
Steering wheel spinner?
What does it do when it finds a field full of pallets?
Can you get a PATS quick hitch for it?
Turning radius?
When you own one, do you occasionally wish you had purchased "a little more tractor?"
i appreciate all that thank you
and i have a question agian : how moving uphill and down hill will effect the traction
   / tractor for maximum traction #47
Work is usually defined as lifting a weight (or mass) a distance such as raising 100 pounds 10 vertical feet requires 1000 ft.-lbs of work. Working on the level you aren't raising anything just over coming the rolling resistance of your tires and the friction caused by the tools ground engagement. Gravity can work both for you (down hill) or against you (up hill). So for any given tractor and implement set up there are three max loads low, middle, and high. Low is going up hill pulling the tool with gravity fighting you. middle is pulling the tool across a flat, and high is pulling the tool down hill with gravity helping you.
thank you
where can i find these three max loads for any tarctor
   / tractor for maximum traction #49
thank you
There are too many variables to pin it down to three exact numbers. How steep is the hill? How wet the soil? What does the tool weigh? How deep it is in the ground . How aggressive are the blades or points.ETC. ETC.
For many tractors you can look up the Nebraska tractor test and see what it's horse power really is and on older models what it's draw bar pull is. After that tires, ballast, tool weight, and soil condition decide weather you can pull it or not. But of course the bigger and more powerful the tractor is, as long as it is set up and ballasted properly, the more it will pull.
Chevy caprice (A55758)
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
Butterfly Artwork (A55758)
Butterfly Artwork...
