Tractor hydraulics and running implements
   / Tractor hydraulics and running implements #11
I've run a pto pump with lines running to a side reservoir and filter and it would be the only easy way I would think would work. I don't know a lot about this but know it worked for me.
   / Tractor hydraulics and running implements #12
Dstig
With a hydraulic motors, flow is speed in RPM and pressure is torque.
With a brush that will operate on 8 - 12 GPM @ 2,000 psi the only variable is speed you will have the same torque at 2,000 psi
Unfortunately you will not have enough flow to run a broom efficiently. Even if you go by the low end of the flow required, it will constantly stall and you will be very unhappy with the performance. You may be able to find a pump and tank combo compact enough to put on the back that will run off the pto and fit between the three point hitch so you can still use the blade, but it will be a tight fit I think.
Yes, unfortunately I am coming to that same conclusion...:( So I will have to start giving more thought to a PTO pump of some sort (or another power source). I had an interesting idea using the front PTO but it needs more thought still...
Thanks for all the input guys.
   / Tractor hydraulics and running implements #14
Wait till spring time. I sold my 72" sweepster, with PTO power pack, and $500 in new bristles for $1500 bucks. They pop up for sale from time to time. Usually April and may in the snow belt. The guy who bought from me threw away the broom and used the power pack for a log splitter.
   / Tractor hydraulics and running implements #15
Yeah I see a few on CL here and there, but none with a hydraulic power pack also, at least so far. $1000 for all that is a total steal.
2017 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2017 DRAGON 150...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
2011 GAYLEAN 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN 130...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
TANK MANIFOLD (A55745)
