tractor hydraulics
   / tractor hydraulics #11
O.K. Bird, thats even better, much cleaner set-up, I'm familiar with the kit. Technically you're still running off of your loader PB, just through the existing tractor plumbing.
   / tractor hydraulics #12
Yep, amounts to the same thing. I just didn't understand Brian's message about not using power beyond and the relief valves. I was wondering whether he meant that I needed to use the power beyond on the top 'n tilt valve also instead of just the inlet and outlet ports, as I'm doing.
Bird
   / tractor hydraulics #15
Bird, Now you have me wondering if I did right or wrong. I took the valve out of a joystick on a B2400 and put it under the seat. I also got a rear block for my power source ( a real bear to put in with the lines on it because the fender is close to the transaxle on the B2400.) but I used the PB conection to return the hydraulic fluid to the 3ph. Now I'll have to watch to find if I'm right or wrong on my hookup.
Bud
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
