FTG-05
Elite Member
- Joined
- Jan 7, 2011
- Messages
- 2,574
- Location
- TN
- Tractor
- Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
This is not a concrete wheel thread, it isn't! I always planned to do a concrete wheel weight thread but after I had them installed and could show the final results. But I made one concrete wheel weight and now I'm trying to get it installed on the right side of my L4330 and so far - it's kicking my butt!!!!
Pics of the wheel weight and how I'm *currently* trying to install it:
Basic wheel weight, +260 lbs of concrete, steel and lead. Note that the threaded 5/8"s Grade 8 bolts on the bottom of the weight in this pic.
And how I'm trying to get it installed:
Overall picture of the operation; please ignore the shift supervisor - as usual with management, she was useless!!!!!!!
I may have forked myself with the design plan of welding the 6 grade 8 bolts and then trying to blindly get them to interface into the 6 holes on the tractor tire. And it also could be a case of major PIA to install, but it's only a one time thing. Since I don't have it done, don't know yet.
As hopefully is obvious in the pics, I'm using my deer pole to lift the weight, then I'm trying to get it aligned with the tractor wheel so I can bolt it up. The problem is that the lifting eye leaves the WW cocked at an angle and I'm having trouble moving, aligning and finalizing the WW into the tractor wheel. I knew this operation would be a challenge, I just didn't think 260 lbs would be that hard.
Comments, suggestions etc. for installing this beast?
Thanks,
Thanks,
