PoorMansCat
Platinum Member
I would check and verify that the gauge is correct before disassembling anything. If you have an temperature gun point it at the top radiator hose near the engine and compare it to the gauge reading.
Another thing to consider, IS it full of coolant. An engine that has air trapped in the system or is low on coolant will sometimes show low coolant temp. (this is due to the bulb on the sensor not being submerged in coolant.) The gauge will read hot air, but not accurately.
As others have stated, being a used tractor, you never know what somebody else may have done, but it is never a good idea to leave the regulator out of the cooling system.
Engines need a regulator in the cooling system to keep the engine components up to a desirable temperature to help aid piston ring seal, keep the engine oil temp high enough to burn off condensation, etc..
In extreme cases, the absense of a regulator can actually cause piston seizure.
